As soon as I turn the ignition key both radiator fan start to spin even though the car is cold and not on. I checked all the relays and fuses. Checked the voltage on the coolant sensor harness with ignition switch on, there is no 5v or the green pin is not grounded. I am clueless where to go next.Please help me with your expert opinion.
I also heard that it can be ac high pressure switch? when I try to turn the ac on it kicks in and turns off immediately also.
But I am just trying to the cooling fan fan problem first as its draining the battery as it stays on all the time. Car runs fine but only problem fan stay on all the time. Please help to solve this issue !!
Sep 5, 2015 at 3:17 PM
