Hi, I have no compression in my 2.6I Microbus motor. I did the head, I checked my fuel pressure. I have spark but no compression.
Feb 10, 2021 at 9:14 PM
✓Experienced Mechanic
If you have no compression, are you certain the timing is correct? Also, you mentioned the head was replaced, was the timing done correctly when you put it back together? Is there any compression?
Let me know if the engine size is correct. I'm showing a 2.4 and a 2.8L as options and not a 2.6.
Let me know as much as you can and if you have other questions.
Take care and God Bless,
Feb 11, 2021 at 9:24 AM
