Boric Acid in gas
120,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
CHARLES SANTOSCOY
Someone poured boric acid in my gas tank. It caused fuel pump to fail. The area where you insert the nozzle to add gas is badly corroded. How do I fix this problem? The fuel gauge is not working and fuel pump failed and blew fuse in one or two minutes after starting car. Already replaced fuel pump. What do I do next?
Oct 8, 2016 at 4:18 AM
HMAC300
  • 48,601 POSTS
Hopefully you replaced fuel gauge sender unless you put in the whole module. you probably can get the corroded part at a dealer or junkyard and just replace it. actually junkyard would be cheaper and okay to use. replace the fuel inlet hose as well and check gas tank which I surmise has already been done. then get a locking gas cap for a while so it wont happen again unless they mess up that. replace the fuel filter if outside the tank as well.
Oct 8, 2016 at 4:46 AM
