Boost problems
2009 CHEVROLET COBALT
110,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
DAMIEN QUIGLEY
My turbo is spooling very slowly and only builds to 11-12 PSI when my normal is 15-18, if I go wide open especially in 4th, it loses boost across the range and only builds to 2 or 3 lbs.
Mar 3, 2022 at 5:26 AM
Good afternoon,
Do you have any codes stored?
Here is a guide that will help with pulling codes if you need it:
Good chance you have a bad wastegate that is built into the turbo.
First, look for any loose or broken clamps from the turbo to the CAC or charge air cooler. A leak will result in a low boost.
The other option is the turbo itself has failed.
Do you have an extended warranty?
Mar 3, 2022 at 6:34 AM
