Bonnet lock not working properly
90,000 MILES • 2.5L • MANUAL
HUSKYMAN 10
  • 26 POSTS
Replaced a full bonnet lock and latch, everything was fine when bonnet was closed. now when I put key in turn left it unlocks, but when I turn key right nothing happens.
Nov 29, 2019 at 8:58 PM
  • 110,248 POSTS
Are you able to get it open at all? It sounds like an adjustment issue. When you installed the new latch, did it work properly at first? Was everything properly tightened?
Let me know
Dec 1, 2019 at 10:52 AM
HUSKYMAN 10
  • 26 POSTS
It was fine when bonnet was closed, still can't open it with wiggling it about.
Dec 3, 2019 at 6:01 PM
HUSKYMAN 10
  • 26 POSTS
I just need to get it open, to check all the bolts are tight.
Dec 3, 2019 at 6:05 PM
  • 110,248 POSTS
Is this a wagon, sedan, or hatch back?
Dec 4, 2019 at 11:28 AM
HUSKYMAN 10
  • 26 POSTS
If you know the car you okay you will know Focus st don't do wagon or sedan.
Dec 4, 2019 at 4:35 PM
HUSKYMAN 10
  • 26 POSTS
Just need to open the latch, without destroying my front grill, and I don't want to damage the new lock or cable.
Dec 5, 2019 at 5:05 AM
  • 110,248 POSTS
I need to determine something. Are you referring to the engine compartment (bonnet) or the trunk area? In the US, the models I mentioned are offered. Additionally, when you say key, in the US that is only in the trunk.
I believe now I understand what you are asking. The key on your vehicle is behind the ford emblem on the front grill. Sorry for the confusion. That is something different than what I see.
When you turn it left it unlocks but the other way, which I believe is the safety latch, doesn't release. Is that correct? Are you able to get between the hood and grill when if first open a small amount?
Dec 5, 2019 at 1:05 PM
HUSKYMAN 10
  • 26 POSTS
Yes, just a small amount.
Dec 5, 2019 at 4:13 PM
  • 110,248 POSTS
Is there a way to reach the release using a long thin screwdriver?
Dec 6, 2019 at 10:48 AM
HUSKYMAN 10
  • 26 POSTS
No because I can't see it.
Dec 6, 2019 at 2:27 PM
  • 110,248 POSTS
They never make things easy. LOL Honestly, this may be a job for a body shop. I'm not familiar enough with the design. I'm sorry about that.
Dec 7, 2019 at 12:24 PM
HUSKYMAN 10
  • 26 POSTS
Well there's the problem, as battery is flat now, and as I can't open bonnet the jump start it, I can't take it to a garage, lol. Okay, thanks anyway.
Dec 7, 2019 at 1:34 PM
  • 110,248 POSTS
It sounds like you have the same kind of luck I have. I'm really sorry I couldn't be of more help. If you get a chance, let me know how it works out for you.
Dec 7, 2019 at 3:32 PM
HUSKYMAN 10
  • 26 POSTS
Okay.
Dec 7, 2019 at 4:15 PM
HUSKYMAN 10
  • 26 POSTS
Still no joy opening bonnet, think I mite need to take the grill of again,!
Dec 9, 2019 at 2:52 AM
  • 110,248 POSTS
Are you able to access the screws to remove it? If so, that would be a good idea.
Dec 10, 2019 at 9:41 AM
HUSKYMAN 10
  • 26 POSTS
Got bonnet open, had to pop the pop in screws between the lights and bonnet, either side, then took the whole front grill of in 1 then opened bonnet.as I have changed it all previously I found the fault. it was the plastic bonnet cable clip that was faulty. ordered new 1 for a few pounds.
Dec 13, 2019 at 12:28 AM
  • 110,248 POSTS
Wow. That was a lot, but I'm glad to hear you got it open. By the way, what you described above will most likely be helpful to someone else, so thanks for letting us know.
Take care and have a good weekend.
Dec 13, 2019 at 10:11 AM
HUSKYMAN 10
  • 26 POSTS
No problem, when taking the front grill of my 07 plate, you don't need to pop all the clips of, only the 2 outside ones, as it's all clipped together you can wriggle it out, although some front grills are different, you will need to check if it's the same standard grill as my own, cheers
Dec 13, 2019 at 8:39 PM
  • 110,248 POSTS
Thanks again. Hope you have a nice holiday season.
Dec 14, 2019 at 10:13 AM
