I need to open a broken bonnet
98,000 MILES • 1.6L • 2WD • MANUAL
ANNIE-JEAN MULCAHY
My bonnet lock is broken so took car to a Ford garage, they removed lock and will have a part in a few days. I need to open the bonnet now and was wondering if this is possible without doing damage.
Oct 6, 2019 at 5:22 AM
BMDOUBLE
  • 1,139 POSTS
It depends how they have latched down the bonnet, with a plastic tie strap? or metal wire? because if you get it open,there is no guarantee that it will close again. If it is held down with a plastic tie strap you may be able to get another tie strap from a hardware store and re-attach it. Can you upload a picture of how it is held down?
Oct 6, 2019 at 5:36 AM
ANNIE-JEAN MULCAHY
No, I can't see in to know weather it's plastic or wire. will have to wait until morning when it's bright to see.
Oct 6, 2019 at 6:21 AM
STEVE W.
  • 15,387 POSTS
Most likely a plastic zip tie, easy to install and easy to remove. Did you get it open or just waited for the new parts?
Oct 9, 2019 at 6:26 AM
ANNIE-JEAN MULCAHY
Still haven't got it opened as I can't see whether it's wire or plastic tied. my car seem to have sorted itself out. my car started going mad, indicators flashing and immobilizer going mental, I was worried about battery dying on me. it all stopped after 4 hours but battery didn't go dead as I kept starting it.. I was thinking it's an electrical fault but was told yesterday by a mechanic that he has seen this happen before, not to a Ford but a different make and said it was a alternator fault. I think the battery in the car is the original Ford battery so was thinking maybe that need replacing.
Oct 9, 2019 at 6:49 AM
STEVE W.
  • 15,387 POSTS
Could be the battery, you can have it load tested to see if it's an issue and that would also show if there is a different issue with the charging system.
Oct 9, 2019 at 8:52 AM
ANNIE-JEAN MULCAHY
Thanks Steve, not much I can do now until Ford ring me to say the part has arrived, once that's sorted I will get straight on to the battery/charging system. Thanks again
Oct 9, 2019 at 11:34 AM
STEVE W.
  • 15,387 POSTS
Okay, let us know how it turns out.
Oct 12, 2019 at 12:56 PM
