Bolts attached to the control arm to the sub-frame removal and installation
1998 FORD TAURUS
160,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DOUGHERTY1989
Why is the bolt facing engine down. nut closest to the ground Reasoning behind bolt is supposed to be like that.
Dec 29, 2019 at 2:38 PM
  • 110,240 POSTS
I'm not sure which bolt you are referring to. Here are the directions for replacing the lower control arm. The attached picture correlates with the directions. Take a look at the pic and let me know specifically which bolt you are referring to. I suspect it is number 5 in the pic.
1998 Ford Taurus V6-183 3.0L VIN U FI
Lower
Vehicle Steering and Suspension Suspension Control Arm Service and Repair Procedures Control Arm Front Lower
LOWER
pic 1
REMOVAL
1. Turn ignition switch to the off position and place steering column in the unlock position.
2. Raise vehicle on hoist.
a. Disconnect height sensor wiring connector.
b. Remove wiring harness from routing clip on front shock absorber.
c. Remove air suspension height sensor from height sensor ball studs.
3. Remove and discard lower ball joint nut. Using Ball Joint Remover T96P-3010-A and Tie Rod End Remover Adapter T81P-3504-W, separate lower ball joint from front suspension lower arm.
4. Using Rotunda Spring Compressor 164-R3571 or equivalent compress front coil spring until lower ball joint clears front suspension lower arm.
5. Remove forward lower suspension arm mounting nut and bolt.
6. Remove rear lower suspension arm mounting nut and bolt. Remove front suspension lower arm from vehicle.
INSTALLATION
1. Position front suspension lower arm into front sub-frame. Install forward and rear lower suspension mounting bolts and nuts. Tighten rear bolt to 98-132 Nm (72-97 ft. lbs.). Tighten front bolt to 77-103 Nm (57-75 ft. lbs.).
2. Release Rotunda Spring Compressor 164-R3571 or equivalent while guiding lower ball joint into front suspension lower arm. Remove spring compressor.
3. Install new lower ball joint nut. Tighten to 68-92 Nm (50-67 ft. lbs.).
a. Install air suspension height sensor onto height sensor ball studs.
b. Position wiring harness in routing clip on front shock absorber.
c. Connect height sensor wiring connector.
4. Install wheel and tire assembly. Tighten lug nuts to 115-142 Nm (85-104 ft. lbs.).
5. Lower vehicle.
________________________________
Let me know if this helps.
Dec 29, 2019 at 3:19 PM
DOUGHERTY1989
In attachment pic 5A for nut on top or bottom of frame does it matter and why if so?
Dec 31, 2019 at 12:19 AM
  • 110,240 POSTS
I just went through the directions. I see nothing indicating it has to be a specific way. If it was mine, I would face the nut in the directions it would be most easy to access. Here are the directions right from Alldata:
1998 Ford Taurus V6-3.0L DOHC VIN S
Lower
LOWER
pic 1
REMOVAL
INSTALLATION
5. Lower vehicle.
Let me know if that helps.
Dec 31, 2019 at 12:15 PM
