Need to know to what degree I turn the cylinder head bolts and torque specs.
Oct 9, 2024 at 5:18 PM
✓Experienced Mechanic
Here are the cylinder head tightening torque specs and the sequence as well in the images below. These are torque to yield bolts so you will need new ones before reassembly.
first pass: 30 nm (22 lb ft)
final pass: 240 degrees
Check out the images (below). Let us know if you need anything else.
