brake rotor to hub bolts bolt spec torque
200,000 MILES
NORBES
I need the Torque spec for the brake rotor to hub bolts.
May 3, 2020 at 12:34 AM
Can you get a picture of the bolts that you are talking about for the rotor? Is this the axle hub nut? Or are you referring to the caliper bracket to the steering knuckle?
Maybe get a picture of it and we will be able to better find the spec. Thanks
May 3, 2020 at 1:36 AM
