Alternator bracket bolt size
213,000 MILES
EIBAND DENNIS
Need to know what size is the bolt is that actually holds the alternator bracket to the motor. the adjustable bolted in place the wing nut bolt the screws into the adjustable bolted in place. but I'm missing the third bolt for the bracket.
Mar 17, 2019 at 4:34 AM
  • 55,746 POSTS
Sizes that hold the alternator and bracket will be 12mm, 14mm and 17mm. Here is a guide to help walk you through the steps with diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-an-alternator
Mar 18, 2019 at 7:15 AM
