Bolt pattern, rims swap
184,000 MILES • 5.7L • V8 • AUTOMATIC
JAMES DARELENTLESS BROWN
Will universal rims off a Chevrolet s10 fit on a 2012 Durango?
Apr 23, 2020 at 9:39 AM
What year S10? The Durango has a 5 lug by 127mm pattern with 34.75mm offset and 6.37 inch backspacing.
Even if the bolt pattern is the same the backspacing and offset has to be the same or the rim will hit the caliper or other components. This can be adjusted for with spacers/adapters but we would have to figure out which one will make it work.
Let me know what year and we can figure out the numbers.
Apr 23, 2020 at 9:53 AM
