Bolt for fuel filter
1991 MITSUBISHI MIGHTY MAX
197,000 MILES • 4 CYL • 2WD • MANUAL
PAULA CHILDRESS GRAVES
I am trying to find an output hose bolt that goes into one end of fuel filter (bottom).
Could it be called something else?
It holds the fuel high pressure hose onto the bottom of the fuel filter assembly.
Any ideas.
Feb 22, 2017 at 4:17 PM
STEVE W.
  • CAR REPAIR CONTRIBUTOR
  • 15,148 POSTS
That would be known as a banjo bolt. You would need to take the old one to be sure you get the correct threads and size. Or take the filter in and test the bolt in it.
Feb 23, 2017 at 7:37 AM
The old bolt is missing so I will take old fuel filter in to check for size! Thanks so much!
Feb 24, 2017 at 4:25 AM
  • 54,189 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Feb 26, 2017 at 7:21 PM
Well I had no luck finding the bolt size. I went by every auto parts store in Memphis and called Gosset Mitsubishi. No one could help with the size. There are several suppliers on line with bolts of every size. So still stuck on what size I need for the 91 Mighty Maxx.
Feb 27, 2017 at 3:51 AM
STEVE W.
  • 15,148 POSTS
Wow, they must not stock much. The bolt is a 12mm X 1.25 thread
Here are some you can get online.
https://www.amazon.com/12MM-1-25-Banjo-Fluid-Adapter-Fitting/dp/B00J0JHQ6I
These even have 1/8" ports that allow you to check the fuel pressure... (just install a plug for normal use)
https://www.pegasusautoracing.com/productdetails.asp?RecID=9276
https://www.summitracing.com/parts/rus-640700/overview/
Feb 27, 2017 at 10:12 AM
Ordered it just now. I cannot fully express my appreciation.
Feb 27, 2017 at 11:22 AM
  • 54,189 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
Feb 27, 2017 at 4:36 PM
