Battery bolt removal
1993 BUICK CENTURY
14,000 MILES • 3.3L • 6 CYL • AUTOMATIC
SHERILYN FRANKLIN
  • 90 POSTS
How do I get to the bolt to unbolt my battery so that I can replace it? It is very hard to get to, I have tried everything.
Aug 11, 2020 at 1:45 PM
  • 110,244 POSTS
Are you referring to the hold down bolt? If so, you should be able to reach it with an extension on the ratchet. Have you tried that?
Take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Aug 11, 2020 at 3:34 PM
SHERILYN FRANKLIN
  • 90 POSTS
I need to see a clear picture of the tool that I need to use.
Aug 11, 2020 at 3:41 PM
  • 110,244 POSTS
I attached a picture of a ratchet with an extension and socket. That is what I believe will be needed to reach the bolt.
Aug 12, 2020 at 2:17 PM
