bogs down
100,000 MILES
DENMAC
car idles fine but when I give it gas it bogs down or looses horsepower, tach goes up but it wont idle high,also when i try to drive it it wont go. just cleaned the throttle plate and checked the sensor that's by the air filter my next step is putting in new spark plugs
May 22, 2013 at 2:13 AM
DOCFIXIT
  • 18,828 POSTS
Could trans be slipping?
May 22, 2013 at 6:37 AM
JOSHR25
  • 5 POSTS
I have the same car. Had the same problem. It wouldn't go up hills either so i cleaned out the throttle bottle sensor it seemed to help a little but not much. So took it to transmission shop and he said i had a leak in my lines which caused to lose fluid and wasnt holding pressure. So had new hoses ran was fixed after that. Good luck hope that helped.
Jun 2, 2013 at 7:12 AM
DOCFIXIT
  • 18,828 POSTS
What happened?
Jun 4, 2013 at 1:32 AM
