When I put it into gear the car bogs down will not move
200,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MARK ALLEN2
When idling it's fine. acts like it's getting no gas. when press the gas pedal the car wants to shut off.
Mar 25, 2020 at 11:55 AM
  • 110,248 POSTS
Is the check engine light staying on when the engine is running? If it is, I suggest having the computer scanned for codes. There are a few different things that can cause this and a code will point us in the right direction. Here is a quick video showing how it's done:
https://youtu.be/YV3TRZwer8k
I realize not everyone has a scanner, but most parts stores will do it free of charge. If that isn't an option, then I would first check fuel pressure. Here is a link that shows how it's done. Based on your description, you may be right. Low fuel pressure can be the cause.
Here are the manufacturer's specs for pressure:
Fuel Pressure .................... 379-393 kPa (55-57 psi)
Next, if that checks okay, then I would confirm there is no issue with a blockage in the exhaust system. A plugged catalytic converter can act this way too. Take a look through these links. The first discusses symptoms and the second how to test.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Lets start with checking those things. Again, if you have access to a scanner and the check engine light stays on, scan for codes and let me know what you find.
Mar 25, 2020 at 4:22 PM
