Body mount bolts
189,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
ESCAPER28
I am installing Nerf bars on my truck which is already 4” lifted. I have to remove the body mount bolts to put on the Nerf bar frame mounts. I do not have to remove bushings just the bolts on front and rear and both sides. My question is, do I need to jack and support the truck while doing this since I am just removing the bolts putting the frame and inserting new bolts?
Jun 23, 2018 at 10:19 PM
Good morning.
No, since you are not removing the bushings, you can just remove the bolts with no worries.
Jun 24, 2018 at 12:40 AM
ESCAPER28
Jun 24, 2018 at 1:32 AM
You are welcome.
Feel free to ask any follow up question if needed.
Jun 24, 2018 at 1:38 AM
ESCAPER28
Do you know what the torque specs are to reinstall these bolts? I have been told 60 and others have said 80. Thanks again.
Jun 24, 2018 at 8:30 AM
80 lbs is the number.
Jun 24, 2018 at 8:43 AM
