Body control module is shorted, open or low voltage?
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CHALKER
I got a used amp and used a y harness behind my uconnect8.4 to do the add on. Come to find out the amp had a short and now my raider has no power at the connector, but I have power at both of the radio fuses #61 in my power distribution center and my 20a in line fuse by the outer fire wall on driver side. Now I also am getting a body control module trouble code saying there’s either a short or no power to some components in the system.
Feb 19, 2023 at 2:05 AM
  • 110,248 POSTS
Is it possible to get the diagnostic trouble code you found related to the BCM? That may point me in the right direction.
Feb 19, 2023 at 2:37 PM
  • 55,691 POSTS
Here is how to scan the BCM to get the codes. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Jan 2, 2024 at 4:38 AM
