Does a replacement Body Control Module need to be programmed?
276,000 MILES • 2.9L • 4 CYL • 2WD • AUTOMATIC
KLEGGSKAA1
  • 22 POSTS
When i get a body control module does it have to be reprogrammed or plug and go.
Feb 21, 2024 at 11:28 PM
BORIS K
  • 836 POSTS
You will have to fit a new or remanufactured BCM. A used BCM already has a pre-programmed VIN and is mated to the donor vehicle. This cannot be overwritten.
If you fit a used BCM the vehicle will not start, and the mileage will be incorrect
Programming can be performed by your local Chevrolet dealer or any independent shop with passthrough availability
BODY CONTROL MODULE PROGRAMMING AND SETUP
BODY CONTROL MODULE (BCM) REPLACEMENT
If the body control module (BCM) is replaced, the following procedures must be performed in the following order:
BCM Reprogramming-Refer to Body Control Module (BCM) Programming/RPO Configuration in Computer/Integrating Systems.
Learning the restraints ID-Refer to Body Control Module (BCM) Programming/RPO Configuration in Computer/Integrating Systems.
Theft Learn-Refer to Programming Theft Deterrent System Components in Theft Deterrent. A new BCM will learn the Pass lock information automatically, but the PCM must still learn the theft information from the BCM.
Program Key Fobs-Refer to Transmitter Programming in Keyless Entry.
Cheers, Boris
Feb 22, 2024 at 12:27 AM
