Body control module
190,000 MILES • FWD
KELLIEWELCH
Where is it located?
Aug 9, 2017 at 8:22 AM
STEVE W.
  • 15,423 POSTS
Under the passenger side dash panel. Remove the sound deadener (if it has one) and the BCM will be visible mounted to the bottom of the HVAC case.
It is not a part that can just be replaced, any replacement has to be programmed to your vehicle for it to work.
What is the issue you are having?
Aug 9, 2017 at 8:55 AM
