2003 BMW Z4 Engine will start, sputter, and die like gettin
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
SWARD1953
I will admit, I drove the car down to virtual empty. It started sputtering and would stay started. Limped home. I've fueled it, but same. It will start for about 5 seconds, then start to sputter, then die. Did I clog the fuel filter possibly by running it so low on gas and picking up some debris at the bottom of the tank?
Sep 29, 2010 at 11:30 AM
DOCHAGERTY
  • 9,606 POSTS
Admitting your sins is the first step towards redemption, you are here by absolved of your sins my child. Just kidding. The possibility of the fuel pump "burning up" is a very high possibility as the fuel that it pumps is the coolant for the pump. If run dry, the pump is at risk.
Sep 30, 2010 at 2:03 AM
