2003 BMW Z4 engine will not start
2003 BMW Z4
DW867WEST
Engine Mechanical problem
2003 BMW Z4 6 cyl Two Wheel Drive Manual
Engine will not turn over,all indicater lights come on,headlights,etc.I have 12v+ reading under hood from batt.Replaced the electrical switch that is under dash mounted where the clutch is.Still nothing.When the ignition switch is turned over no lights go dim,we have moved the car back and forth to see if starter was stuck being it is manual shift,still no result.
Feb 2, 2010 at 2:03 PM
DOCHAGERTY
  • 9,606 POSTS
Have you determined a source of the no start? Is it the EWS alignment?
Feb 28, 2010 at 2:09 AM
