i just replace new battery then airbag light is on . Could you tell me what i need to fix it . Thanks
Jan 4, 2009 at 12:08 AM
DOCHAGERTY
✓Experienced Mechanic
The SRS light is on because there is a failure in the airbag system. The cause may be due to the seat mat sensors or the seat belt pyrotechnics are setting a resistance fault, either way you will need to have the fault read out and address it as required.
Jan 4, 2009 at 3:32 AM
BUCKEYE3161
MEMBER
1 POST
I also had the same problem when I disconnected the negative terminal cable. Looks like the only solution is to visit the dealer. Sweet, that's user friendly!
