2003 BMW Z4 battery
2003 BMW Z4
32,100 MILES • 6 CYL • 2WD • AUTOMATIC
TIGER01NGUYEN
i just replace new battery then airbag light is on . Could you tell me what i need to fix it . Thanks
Jan 4, 2009 at 8:08 AM
DOCHAGERTY
  • 9,603 POSTS
The SRS light is on because there is a failure in the airbag system. The cause may be due to the seat mat sensors or the seat belt pyrotechnics are setting a resistance fault, either way you will need to have the fault read out and address it as required.
Jan 4, 2009 at 11:32 AM
BUCKEYE3161
I also had the same problem when I disconnected the negative terminal cable. Looks like the only solution is to visit the dealer. Sweet, that's user friendly!
May 11, 2009 at 9:56 PM
DOCHAGERTY
  • 9,603 POSTS
You should let BMW NA know your feelings.
May 11, 2009 at 10:27 PM
