2002 BMW Z3 ODB Code P0455 Evap Leak Large
48,000 MILES • 6 CYL • 2WD • MANUAL
BRIDGE246
The check engine Light has been on for a couple of months. The Code reader found code P0455. I changed the gas cap and waited a couple of weeks but the light did not go off, so I had a mechanic double check the code (he verified P0455) then he turn the warning light off. I 'm wiating to see (about 100 miles) if the light comes back on.
I have no other noticable symptoms, eveything seems to be runnig fine, there is not any type of gas smell, etc. The car only has 48K miles.
1) What are the most cost effective steps to trouble shooting this problem? 2) Are there any trouble shooting steps that I can do before taking it to the BMW dealer and paying a fortune? 3) Is there a free on-line BMW reapir manual so I can see what I could do myself? Or at least understand the mechanic when he talks to me aobut the problem.
Mar 24, 2009 at 3:32 AM
DOCHAGERTY
  • 9,606 POSTS
When you changed the gas cap, did you reset the service engine soon light? It will not turn itself out.
Apr 19, 2009 at 3:19 AM
BRIDGE246
Thank you for the help.
I just had the engine light reset about a week ago and I've since driven about 300 miles and the light has not come back on. I'm thinking that the new gas cap worked and the problem is solved. Thank goodness.
Apr 19, 2009 at 4:09 AM
DOCHAGERTY
  • 9,606 POSTS
Anytime, you are welcome.
Apr 19, 2009 at 10:38 AM
