2000 BMW Z3 Replacing radiator
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIRDWATCHERYANK
What are the steps involved in removing and replacing the radiator?
Nov 3, 2008 at 1:10 PM
IMPALASS
  • 3,112 POSTS
Hello
First I need to know is it a Z3 Coupe (E36/7) or a Z3 Roadster 2.5 (E36/7) or a Z3 Roadster 2.8 (E36/7) and I will be glad to send you the info.
Nov 3, 2008 at 1:54 PM
BIRDWATCHERYANK
My car is a Z3 roadster comvertible with a 2.3 liter engine. Year is 2000. Thanks
Nov 4, 2008 at 2:19 AM
IMPALASS
  • 3,112 POSTS
Hello - Here you go...........good luck Caution: Danger of scalding Only open sealing cover on expansion tank when engine has cooled down. Drain coolant, refer to Cooling System - Service and Repair - Procedures See: Service and Repair Remove fan cowl, refer to Fan Shroud - Service and Repair - Procedures See: Fan Shroud\Service and Repair Note: When removing the fan cowl, note the engine variant.
https://images.2carpros.com/forum/automotive_pictures/248015_R1_1.gif
Air conditioner Disconnect plug connection on temperature switch.
https://images.2carpros.com/forum/automotive_pictures/248015_r2_1.gif
Disconnect upper water hose.
https://images.2carpros.com/forum/automotive_pictures/248015_r3_1.gif
Disconnect lower water hose.
https://images.2carpros.com/forum/automotive_pictures/248015_r4_1.gif
Disconnect expansion hose.
https://images.2carpros.com/forum/automotive_pictures/248015_r5_1.gif
Automatic transmission Remove transmission oil cooler lines, catch transmission oil as it escapes and dispose of correctly. Installation: Check transmission oil level and correct if necessary, refer to Transmission and Drivetrain. Check connection for leaks.
https://images.2carpros.com/forum/automotive_pictures/248015_r6_1.gif
Unfasten left and right radiator mounts by pressing detent down with screwdriver.
https://images.2carpros.com/forum/automotive_pictures/248015_r7_1.gif
Sectional view of radiator mount: Screwdriver Front trim Retaining lug for radiator
https://images.2carpros.com/forum/automotive_pictures/248015_r8_1.gif
Installation: Attach retaining lugs in left and right sides of radiator and press down firmly. The detent must engage audibly several times.
https://images.2carpros.com/forum/automotive_pictures/248015_r9_1.gif
Installation: Use screwdriver to locate and lug of radiator mount and to tighten the unit.
https://images.2carpros.com/forum/automotive_pictures/248015_r10_1.gif
Lift radiator upwards (together with intercooler if applicable). Installation: Place radiator on supports.
https://images.2carpros.com/forum/automotive_pictures/248015_r11_1.gif
Installation: Note rubber mounts on left and right sides.
Nov 4, 2008 at 6:02 AM
