2000 BMW Z3 Code P0340 and or P1397
57,000 MILES • 6 CYL • 2WD • MANUAL
TBURCK
Service Engine light came on after engine was running great. Engine missed a few beats and stalled in a parking lot when hot. Then set code. Code P0340 Camshaft Position Sensor Circuit Malfunction. Check on internet, most people said, change cam sensors. Installed both new sensors with no problems. Cleared codes and road tested. Car ran fine at first, but after a hot start in a parking lot and a stall or two. Service light reset and code P0340 came up again. I can clear code but after short time of running and stall or two, seems to reset same code.
Oct 14, 2008 at 6:45 PM
DOCHAGERTY
  • 9,606 POSTS
Where did you get the sensors?
Oct 15, 2008 at 2:02 AM
TBURCK
Got the sensors on line from Bavarian Autosports. They did look and fit great. My only worry is with electronic parts from on line companies, hard to return and part quality. The way this is playing out, could it be a hot short?
https://images.2carpros.com/forum/automotive_pictures/256299_BMW_Z3_1.jpg
Oct 15, 2008 at 4:17 AM
DOCHAGERTY
  • 9,606 POSTS
Parts warranty the sensors.
Oct 15, 2008 at 3:30 PM
