1997 BMW Z3 Throttle position sensors
1997 BMW Z3
77,000 MILES • 6 CYL • 2WD • MANUAL
UGLYBOY
I have a problem starting my bmw z3 when it is cold. I have to keep the rpm up to keep it going. Once it is warmed up, it runs fine.
The error code, shows a throttle position sensor error. I have replaced both the primary & secondary throttle postion sensors, but still get the error, and still have problems starting the engine when cold. Is there any further setup I need to do?
Thks
Antony
Dec 4, 2009 at 3:41 PM
Hi uglyboy and TY for the donation
Try this Inspect and test the coolant temperature sensor and the idle speed control valve
Dec 5, 2009 at 3:00 PM
