1997 BMW Z3 runs hot
1997 BMW Z3
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALBERT4
have changed out all the reg stuff water pump thermistat , rad is clear , water level is full. elect fan ok , reg belt fan ok,heater does not work but i think it is just a value. do you think it has a blown head gasket? if so why does it run so smooth? have seen no smoke in the exhust. also what do you think of steel seal for a repair. thanks al harris
Jan 14, 2008 at 10:19 AM
DOCHAGERTY
  • 9,606 POSTS
remember to bleed all the air from the system. there is a bleeder screw that is black plastic on top of the expansion tank. Get a Bentley manual from Amazon.com
Jan 22, 2008 at 10:51 AM
