1997 BMW Z3
VBRUNETTE
1997 BMW Z3 4 cyl Automatic 43,000 miles
I have a 1997 BMW Z3 with 43,000 miles. I went on a short errand and had travelled about 2 miles from home when the car stalled at a light. It was a hot day...90 degrees and the air conditioning was on. I turned the a/c off and attempted to re-start the car a few times. It turned over but sputtered out. I had to have it towed to the local BMW dealership. After four days in the shop, the dealership said that the car had a clean computer code, started just fine and they could not re-create the problem. It would seem to me that this is not normal and now I have no confidence that it won't quit on me the next time I take it out. Has anyone else encountered this problem with the Z3?
Jul 13, 2010 at 3:47 PM
DOCHAGERTY
  • 9,606 POSTS
About how much fuel was in the tank when the stalling occurred?
Jul 13, 2010 at 3:56 PM
VBRUNETTE
The tank was about 3/4 full and I use 89 octane.
Jul 14, 2010 at 3:31 AM
DOCHAGERTY
  • 9,606 POSTS
The dealers' inability to recreate the issue does not surprise me. Typically this type of intermittent issue is caused by either a fuel delivery issue or an electrical pathway that had been temporarily compromised. What this could mean is the fuel pump could have been vapor locked or the relay that controls the pump had been unable to make the connection to the pump from the power supply. There is also a possibility the power train control electronics have some sort of intermittent (there's that word again!) issue that does not or did not show up on the dealers scan of the car. This leaves me with little else to say as I am not the tech repairing the car and it is not sitting on my lift at work so that I can see it for myself. Have the dealer get someone to drive the car until it has the same issue.
Jul 15, 2010 at 1:34 AM
VBRUNETTE
Thanks so much for the possible explanation for what happened. At least that makes sense to me. The suggestion that absolutely nothing was wrong or had occurred to cause the stall did not make sense to me. The dealer told me they did multiple test drives and after doing so, felt they had done enough. They told me to pick up the car. I drove it home last night (about a 15 mile ride) without a problem. I will save your post and if this does happen again will suggest they check the items you mentioned.
Jul 15, 2010 at 1:48 AM
DOCHAGERTY
  • 9,606 POSTS
Please keep in mind that intermittent issues are the most difficult ones to recreate and repair. The dealer has a somewhat limited attention span when it comes to "intermittent" if you get my meaning.
Jul 15, 2010 at 2:08 AM
VBRUNETTE
Yes, it became apparent to me that my "intermittent" problem was not on the top of the priority list. One last question...if the problem is any of the things you mentioned in your earlier post, is the car only likely to stall when I am stopped or might that happen while it's actually driving...my fear is that this will happen when I'm on the highway going at a decent clip.
Jul 15, 2010 at 3:05 PM
DOCHAGERTY
  • 9,606 POSTS
Your fear is reasonable, I get it. The possibility of it happening on the freeway is difficult to calculate and I would feel better about recommending something if more data were available, right now I would say drive the car and see what happens.
Jul 16, 2010 at 1:43 AM
