P1092 And P1093
80,000 MILES • 6 CYL • AWD • AUTOMATIC
AHMAD MALALHA
P1092 pre-catalyst fuel trim too lean bank 2
P1093 per-catalyst fuel trim too rich bank 2
We changed the fuel filter, air filter and oil filter.
Engines light remains on with code :
Thanks
Jul 27, 2010 at 8:35 PM
  • 55,628 POSTS
Hey Ahmad Malalha,
This is a classic MAF sensor problem, I would try cleaning it first and then replace it if the problem continues.
Here are some guide to help you out.
https://www.2carpros.com/articles/mass-air-flow-service
and
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Then clear the codes.
https://www.2carpros.com/articles/check-engine-light-clear-codes
If this does not work I would check the fuel pump for low pressure here is a guide to help
should be at about 50 psi
Dec 4, 2016 at 1:42 PM
