2005 BMW X5 Electric mirrors fold in and straight back out
2005 BMW X5
75,000 MILES • V8 • 4WD • AUTOMATIC
8459REBECCA
Please help!!
When pressing the button to fold the mirrors in, they go in and then straight back out. Someone has advised there may be a problem with the micro switch and if I take the painted mirror back off and try to straighten the metal u bend switch it may solve the problem?
Is this likely, and what's the best way to remove the painted cover as don't want to break it?!
Your info would be greatly appreciated.
Thanks in advance.
Feb 22, 2009 at 3:36 AM
DOCHAGERTY
  • 9,606 POSTS
I need a bit of clarity please. "Someone" had advised you to straighten the metal u-bend switch in the mirror. There is no switch inside the mirror, who was this person? If the mirror motors are working then the removal of the painted covers only risks breaking something, the plastic used is somewhat brittle, especially when cold. When you introduce a request for the mirrors to fold, do you press and hold the button or do you tap it once and let it go? Is the button "sticky". How long has this issue been bothering you? When did you first notice it?
Feb 22, 2009 at 3:48 AM
8459REBECCA
Thanks for your reply. Only had car a few months and have never worked since we first tried.I just press the button, don't hold it in and it doesn't appear "sticky". The place I bought it from said it's probably a fault with micro switch and when I researched on internet someone advised they had same problem and took the back off, removed a black square plastic box to find the switch with u bend metal piece in it. Try to straighten this a bit at a time to see if solves the problem.
The drivers mirror has a very small mark on outside, so I'm not sure if was caught before I had the vehicle.
Would anything show up on a diagnostic?
Feb 22, 2009 at 8:20 AM
DOCHAGERTY
  • 9,606 POSTS
The square plastic box is the mirror motor and it or they might be causing this issue as they are actuated via a LIN bus and have been known to cause problems. First you might want to ask yourself if it is worth it to repair an issue that is not keeping the car from getting down the road, if you catch my drift.
Feb 22, 2009 at 11:45 AM
