2004 BMW X5
GMINI
Electrical problem
2004 BMW X5 6 cyl
My engine light keeps coming on, OBD Code reads P1092 I have replaced the O2 sensors on the exaust manifold as it said before the catalyst, What else do I need to do?
Feb 15, 2010 at 2:57 AM
DOCHAGERTY
  • 9,606 POSTS
What is the mileage of the vehicle? Have you inspected the entire intake system for leakage? OBDII fault code generation is sometimes not precise when dealing with a generic scan. A too lean condition (P1090 & P1092) is most often a torn boot at the intake and it can hide from view. The boot can crack as it deviates to send air to the idle air control valve, check that and the cyclone separator can also be a problem depending on the age and mileage.
Feb 16, 2010 at 11:21 PM
