2003 BMW X5 trsmision slip
2003 BMW X5
SHAHOON
  • 5 POSTS
Transmission problem
2003 BMW X5 V8 Four Wheel Drive Automatic 125 km miles
dear sir
i was wodering about my x5 transmision it was working normally one day i reach my work park the car and go for 2 hours i recognize after i come back that the transmision is slipping much after i run for few kilometers the gearbox engage again with normal performance.
the main problem that im having the same problem every time i leave the car especially in the morning time i have to run for few kilometers with slipping gear
action taken: change the oil and the filter of the [img:02b7eb995c]http://www.2carpros.com/forum/automotive_pictures/317083_n823705573_5795574_3345_1.jpg[/img:02b7eb995c]trns.
still the same
change the oil pump of the gear
same
changing the clutch and the drums again the problem still there the mechanic said that the gear box inside after he open still in good conition im afraid to change the gear but the problem will be some sensors or sth simple any advice
your support appriciated...
Feb 13, 2009 at 1:20 AM
DOCHAGERTY
  • 9,606 POSTS
Wow, you had the tranny all apart and could not find anything? Sounds like the shift body might have a broken spring or some other problem like a stuck piston or an occluded passageway. And it could also be a speed sensor issue.
Feb 13, 2009 at 8:47 PM
SHAHOON
  • 5 POSTS
dear
i noticed sth when the temperture of the car reach the middle the gear willl work properly some of them they said the temperature thermostat do you think that will coz this by the way if you leave the car for hours running you will never c changing in the temp it is stable in the middle is there any connection betwwen the thermostat and the trns.
and if its the speed sensor what is it role and how i change it where it is located.
dr. hagerty really you r saving me big thanks and im ready for any thing you ask if you find my problem ....
Feb 14, 2009 at 12:08 AM
DOCHAGERTY
  • 9,606 POSTS
I can be of more assistance to you when I get to my home computer. Sunday by 1:00 in the afternoon, I am sorry about the delay.
Feb 14, 2009 at 10:34 AM
SHAHOON
  • 5 POSTS
where r you living so i can know the timing difference
Feb 15, 2009 at 12:43 AM
DOCHAGERTY
  • 9,606 POSTS
I am in California. Pacific coast time
Feb 15, 2009 at 10:48 AM
SHAHOON
  • 5 POSTS
dear
did you find the problem in my car or as i asked you before about the speed sensor...
Feb 15, 2009 at 11:06 AM
DOCHAGERTY
  • 9,606 POSTS
There is a production split that year and I also need the VIN to be sure I am quoting you the correct information.
Feb 15, 2009 at 4:47 PM
SHAHOON
  • 5 POSTS
what is the VIN
Feb 15, 2009 at 9:58 PM
DOCHAGERTY
  • 9,606 POSTS
Vehicle Identification Number. It is composed of 17 letters and numbers and is a sticker visible on the drivers door "B" pillar, and on the very top of the dash board right up next to the windshield there is a metal plate. It is also on the registration card.
Feb 16, 2009 at 11:20 AM
DOCHAGERTY
  • 9,606 POSTS
Are you there?
Feb 19, 2009 at 10:12 PM
