2003 BMW X5 The battery
2003 BMW X5
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRADFORD COX
Is the battery that comes with the X5 special? Do you have to get another BMW battery? Or can I borrow the one out of my Rav 4 to get it started?
Nov 10, 2008 at 1:48 PM
  • 31,937 POSTS
Hi there,
This car will have a DIN type battery, you will see that the battery post are no higher than the battery case, ad if you fit a more conventional battery it may cause a problem, just be aware of metal striking the pos terminal as this will cause a flash and can often destroy electrical equipment, i would be fitting the correct battery.
Mark (mhpautos)
Nov 10, 2008 at 3:56 PM
