Before you get started you want to make sure that the engine is cool.
Raise and support the vehicle with jack stands.
You will have to remove the drive shaft in order to get the converters out.
https://www.2carpros.com/articles/catalytic-converter-replacement
To make the removal of the oxygen sensor easier, you will have to use a oxygen sensor socket.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
I have attached replacement procedures for the catalytic converters as well as the oxygen sensor.
Images (Click to enlarge)
Sep 16, 2021 at 1:34 PM
