2003 BMW X5 BMW X5 Transmission Problem
2003 BMW X5
GTRICKSTA
Transmission problem
2003 BMW X5 V8 Four Wheel Drive Automatic
Hi all.I got a problem with a 2003 BMW X5.It got 4.4i V8 Engine.
The problem is; when the car is cold,I'm driving it until engine gets heat,the gear distances are getting longer.Gear is changing at 4000-5000 RPM(Like performance cars).What can I do?
I tried so many transmission brains but they didn't work.I changed the radiator's water and transmission oil cooler.It didn't work too.Can you help me please?
Thanks.
Aug 2, 2008 at 6:16 AM
DOCHAGERTY
  • 9,606 POSTS
Have you considered that it may be a stuck piston in the valve body of the tranny?
Aug 3, 2008 at 12:34 PM
GTRICKSTA
[quote:1752424cde="Dr. Hagerty"]Have you considered that it may be a stuck piston in the valve body of the tranny?[/quote:1752424cde]
Thanks for reply:)
I changed 2 valve body of transmission.But it didn't work.I'm going 80km. or 50miles everything is alright but later then 50miles the car is getting S Position.The gear distances are getting longer changing at 4000-5000 RPM.I'm waiting for your helps.Thanks.
Aug 3, 2008 at 10:12 PM
DOCHAGERTY
  • 9,606 POSTS
Who replaced the valve body? Was it torqued correctly? The issue of which you speak can be due to an incorrect sequence in the tightening of the screws. Has the software been updated? Are there faults set? If so what are they?
Aug 4, 2008 at 12:39 AM
