2003 BMW X5 A/C Blows but is NOT COLD.
2003 BMW X5
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
MABEL01
My 2003 X5 3.0i Total 89K, after being garaged for 2 years and driven maybe 2-3 times a month, stop cooling, we can hear the fan blowing and everything but the air is not cold. Just room temperature.
The heater was not on in case you asked me. We just turned the A/C. 1 day before it went out, we charge the battery as the car just died. There is no bad odor, (usually the sign for a leak). Would be possible for something else other than A/C Evaporator Core to be failing since I seem to have NO LEAK?
Appreciate help with reply to: Mabel@shipCGL.com
Aug 21, 2010 at 3:14 PM
Start by checking the high and low pressures this will tell you if it has the amount of freon-
Aug 21, 2010 at 6:16 PM
