2002 BMW X5 parasitic draw
2002 BMW X5
85,000 MILES • 6 CYL • AWD • AUTOMATIC
NGHIAANDNHU
Vehicle will drive fine for weeks on end, sometimes months. However, about once every month it will not start without jumper cables. Nothing's ever left on to drain the battery. Please advise.
Jul 22, 2009 at 10:33 PM
Get the charging system check out if okay do battery drain test below
[imghttps://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_114.jpg[/img] draw
Jul 23, 2009 at 4:28 AM
DOCHAGERTY
  • 9,606 POSTS
Check the fan final stage, if voltage is present at the heat sink or it is warm to the touch, replace it. Go to Realoem.com for your part, it is in the 64 section.
Jul 23, 2009 at 9:25 AM
