I'm contemplating changing the boot myself - I'm reasonably competent and have a lift and air tools at my disposal. The boot has just recently begun throwing a small amount of grease, so the joint should still be OK.
I'm wondering how difficult it is to remove the front halfshaft on the X-5?
Will I need to dismantle the front suspension including compressing the spring, or does the shaft slide out with the suspension intact?
Dec 8, 2008 at 7:51 AM
