2002 BMW X5 Drivers side door
2002 BMW X5
114,000 MILES • V8 • 4WD • AUTOMATIC
FCARADONNA
The door handle inside the car will not disengage the door lock. It will open from the outside handle though. If you park car you need to lower window and pull outside handle to unlatch and open door.
Feb 8, 2009 at 5:21 AM
DOCHAGERTY
  • 9,606 POSTS
The Bowden cable has broken and will require replacement. This will require removal of the door panel. Part number for your cable is 51-21-8-403-057. Go to Realoem.com for an exploded view.
Feb 8, 2009 at 1:11 PM
