2002 BMW X5 alternator drive belt removal
GREEKCARUSO
  • 2002 BMW X5
Engine Mechanical problem
2002 BMW X5 6 cyl All Wheel Drive Automatic
How do you remove the alternator/waterpump drive belt? The AC/power steering belt had a typical tensioner.
I can not see how to relieve the tension on the alternator belt.
Monday, April 14th, 2008 AT 8:56 AM
DOCHAGERTY
  • 9,601 POSTS
There are two black pulleys that have covers that pop off, one is called the tensioner pulley and one is called the deflection pulley. The tensioner pulley cap, once it is popped off, has a Torx bolt, if you turn that bolt clockwise, it will relieve the belt tension. The deflection pulley is fixed and will have a 16MM bolt head under it's cover, do not remove that one, just put the cap back on.
Monday, April 14th, 2008 AT 10:51 AM
