2002 BMW X5 2002 X5 CUTTING OUT WHEN IDELING?
2002 BMW X5
77,000 MILES • 6 CYL • AWD • AUTOMATIC
LUNN1984
Hi, my 2002 4.4i x5 runs and performs fine while driveing but when sat a set of traffic lights it runs quite rough and cuts out, ive replaced the air flow meter and had the fault memory cleared and also had the throttel body cleaned out but its made no difference.any ideas?
Dec 1, 2008 at 5:13 AM
DOCHAGERTY
  • 9,606 POSTS
What faults were set? How were the fault codes extracted? Also please repost with the VIN and what history you know of the car and what has been tried to remedy this issue in the past.
Dec 1, 2008 at 6:17 AM
LUNN1984
hi, the vin is wbafb32010ln83967.the first time the fault occured the engine light came on,when the garage put it onto the computer it said the air mass sencor was at fault so this was replaced and the engine light turned off,then arfter about 10 miles the car started ideling low and cutting out when it stoped, i took the car to a different garage and and when they put it onto the computer it brought up 3 faults.
:140- characteristic thermostat open circuit
:26 - mix adapt 1 {mutiple, bank1} at control stop.
:27 - mix adapt 1 {multiple, bank2} at control stop.
The throtle body was also removed and cleaned at the same time and they reset the idel adaption, the car was road tested and no faults returned but the idel speed is still low.this is the first problom of this type with the car.
Dec 3, 2008 at 10:52 PM
DOCHAGERTY
  • 9,606 POSTS
Then request the idle speed to be increased by 75 RPM. This can be completed through the GT-1 by most who are skilled with this device.
Dec 4, 2008 at 2:11 AM
