2001 BMW X5 Tune Up
2001 BMW X5
85,000 MILES • 6 CYL • AWD • AUTOMATIC
UHENRY1
When it the appropriate time to due tune up for 2001 BMW X5? The car is 85,000 miles on it and I bought is used so I do not know when they due tune up.
Apr 15, 2009 at 8:38 AM
DOCHAGERTY
  • 9,606 POSTS
BMW does not refer to maintenance as "tune up" rather it is a maintenance procedure called an inspection. At 85k miles it should have had an inspection II at 60k. An inspection usually calls for replacement of fluids and filters and a visual inspection of the under carriage and power train and addressing whatever issues may need repair or adjustment. Simply stated it means changing the engine oil and filter on a time/mileage basis and seeing what the car needs to be safe for you to drive.
Apr 19, 2009 at 3:09 AM
