2001 BMW X5 Self Level Suspension Inactive
2001 BMW X5
81,000 MILES • V8 • 4WD • AUTOMATIC
VINESTER
For some reason, the rear air suspension has become fully extended and the back of the car is now sitting at least 6 inches higher than normal, and the ride is so stiff it is unbearable.
I have checked all related fuses and replaced the battery in the hope of getting a quick fix. To no avail...
Why would the suspension fulley extend and how can I get it to return to normal?
Many thanks
Martin
Jun 4, 2008 at 7:18 PM
DOCHAGERTY
  • 9,606 POSTS
There may be something wrong with the control unit and the only replaceable part is the relay that controls the pump. P/N 61-36-8-373-700. The system is readable for faults with the BMW proprietary software, you may have to seek out someone who has access to it.
Jun 5, 2008 at 2:21 AM
CTX5
Check the fuse for the air suspension. Fuse #87 in the trunk fuse box. I replace mine and the problem went away. Good Luck
Dec 30, 2010 at 8:44 PM
DOCHAGERTY
  • 9,606 POSTS
CTX5, did you actually read the first post?
Dec 30, 2010 at 9:26 PM
