2001 BMW X5 oil pan (sump) replacement
72,000 MILES • 6 CYL • AWD • AUTOMATIC
IOPM33
Hi is it posible to chance a oil pan on a bmw x5 3.0i with limited knowledge and tools is it a big job it look it does drive shafts etc run though it i have to change it has it has a crack thans for your help
Apr 11, 2010 at 7:25 AM
DOCHAGERTY
  • 9,606 POSTS
If you take it on, I suggest you go to Amazon.com and get a Robert Bentley manual. The warranty time is about 9 hours so it is probably wise for you to double that time. I also caution you that it takes special tools, without them you are not going to be efficient, or even successful. If fixing BMW cars were easy, anyone could do it.
Apr 11, 2010 at 12:40 PM
