2001 BMW X5 driver door wont open from outside
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
XHELLLIX
hi my x5 driver door wont open from the outside when u pull the door handle, u have to go inside the car from passenger side and open the driver side from there. what do u think is the problem? do i have to replace the entire door lock assembly? if so, what do u think is the estimated cost including labor thanks?
Dec 8, 2009 at 8:35 PM
DOCHAGERTY
  • 9,606 POSTS
There is a great exploded veiw of inside the door of your car at Realoem.com I would guess the part you need to be the door carrier, part number 51-21-8-243-615 It is fairly easy to install, for me anyway, for you it might not, I dont know your level of commitment. If you want to take it on, let me know, I'll talk you through it.
Dec 10, 2009 at 1:43 AM
