2001 BMW X5 correct fuse
2001 BMW X5
CHUCK5690
Electrical problem
2001 BMW X5 46375 miles
I need to check the fuse for the fog lights, but do not find it marked in the glove box or the trunk fuse panels. Is it connect to another system that I need to pull and check? There are so many fuses I am hoping to eliminate haveing to pull all of them. Thanks for your help.
Jan 28, 2008 at 3:03 AM
DOCHAGERTY
  • 9,606 POSTS
the fuse for the fog lamps is in the main fuse panel in the glove box, the legend will direct you. It is the white paper that pulls out from the cover.
Feb 21, 2008 at 8:45 AM
