2001 BMW X5 code P1158/P1160
111,022 MILES • V8 • 4WD • AUTOMATIC
MYSWEETX5
  • 16 POSTS
AFTER REPLACING (EGR VALVE) AND CLEAN THE (MAF)
CAR RUNNING OK, BUT AFTER DRIVING 3 MILES SERVICE ENGINE LIGHT COME ON AGAIN WITH DIFFERENT CODES (P1158/1160) FUEL ADDITIVE SOMETHING LIKE THAT. BUT BEFORE IT USED TO BE (LEAN CODE: P0171/P0174. COULD IT BE THE SAME SITUATION.
Sep 28, 2010 at 11:30 PM
  • 75,988 POSTS
Lean conditions
P1158/P1160
Go to this link: https://www.2carpros.com/trouble_codes/obd2
P0171/P0174
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Sep 28, 2010 at 11:56 PM
DOCHAGERTY
  • 9,606 POSTS
Lets get the facts straight, EGR was not installed on this car. BMW has not used EGR for a long time. What was done, what was replaced and what method was used to pull codes? Generic code readers dont always tell the tale. Have you replaced the pre-cat oxygen sensors yet?
Sep 29, 2010 at 2:37 AM
MYSWEETX5
  • 16 POSTS
AS A PROFESSIONAL, I TRUST YOU BUT YOU CLAIMED THAT (BMW DID NOT USED EGR VALVE) SPECIALLY ON MY CAR MODEL. AND THIS IS WHAT I HAVE REPLACED IN FRONT OF THE ENGINE ON THE SIDE.
https://images.2carpros.com/forum/automotive_pictures/504541_BMW_X5_EGR_VALVE_1.jpg
https://images.2carpros.com/forum/automotive_pictures/504541_mysweetx5_2.jpg
Nov 10, 2010 at 1:16 AM
MYSWEETX5
  • 16 POSTS
ALSO THIS VEHICLE USED TWO DIFFERENT EGR VALVE: (THE BLACK ONE THAT COVER THE REAR INTAKE MANIFOLD) ALSO CATEGORIZED AS (EGR VALVE). AND THE OTHER ONE PICTURED.
https://images.2carpros.com/forum/automotive_pictures/504541_REAR_INTAKE_COVER_VALVE_1.jpg
https://images.2carpros.com/forum/automotive_pictures/504541_BMW_X5_EGR_VALVE_2.jpg
Nov 10, 2010 at 2:11 AM
DOCHAGERTY
  • 9,606 POSTS
The valve is for the secondary air injection, not EGR. The plate IS the PCV valve on the back of the intake manifold.
Nov 10, 2010 at 10:01 PM
