2001 BMW X5 axle replacement
95,000 MILES • 6 CYL • AWD • AUTOMATIC
GTOSMINE
is there any special way to install these axles right and left sides or is this straight forward like any other cars
thanks
larry
Jan 26, 2008 at 4:23 AM
MERLIN2021
  • 17,250 POSTS
The difference between BMW and others is the inboard joint, you will need to remove the bolts holding the two flanges together...
Jan 26, 2008 at 4:29 AM
GTOSMINE
[quote="gtosmine"]Transmission problem
2001 BMW X5 6 cyl All Wheel Drive Automatic 95000 miles
these axles do not have flanges it seams to me they just pull out there is nothing holding them in
Jan 26, 2008 at 4:34 AM
MERLIN2021
  • 17,250 POSTS
Then it's OK to pop it out, BMW used them when I was working on em...few years back!
Jan 26, 2008 at 4:48 AM
GTOSMINE
[quote="gtosmine"][quote="gtosmine"]Transmission problem
do these axles go in any special way
thanks
larry
Jan 26, 2008 at 4:52 AM
MERLIN2021
  • 17,250 POSTS
When you remove the old one you will see a lock ring in a groove at the inner end. They just push in...I used a dead blow hammer, it's a sand filled plastec hammer, it causes no damage to the metal...
Jan 27, 2008 at 1:38 AM
