2000 BMW X5 won't start
WVTHALL
  • 2000 BMW X5
  • V8
  • AWD
  • 78,000 MILES
I have been having trouble with the car not starting. It will crank and fire quickly but not start. After many tries it will eventually start. Sometimes it will stall after a few minutes of driving and other times it will drive just fine. I have replaced the fuel filter spark plugs. Could it be the camshaft sensor or the crankshaft sensor?
Tuesday, July 22nd, 2008 AT 8:44 PM
DOCHAGERTY
  • 9,601 POSTS
If it was a sensor it would turn the check engine light on. Is the light on? If so, have you checked the fault codes?
Tuesday, July 22nd, 2008 AT 9:54 PM
WVTHALL
Thanks for your response. The service engine light is on the hazard light is in on in the center but no check engine light.
The codes that come up are OF 8d (engine cooling fan control)
A4- ambient pressure sensor
78-vehichle speed
Wednesday, July 23rd, 2008 AT 9:42 AM
WVTHALL
Another code that came up previously was catalyst efficiency thanks again.
Wednesday, July 23rd, 2008 AT 10:12 AM
DOCHAGERTY
  • 9,601 POSTS
It could be many things, could you repost with the VIN please. I will run a history through DCS and see what has been done at the dealership level.
Wednesday, July 23rd, 2008 AT 8:28 PM
CLEVS
  • 5 POSTS
The vehicle speed fault you are getting is one of the crank or cam sensors, think its cam but not 100% sure.
Friday, August 22nd, 2008 AT 4:05 PM
DOCHAGERTY
  • 9,601 POSTS
Crank or cam sensors might throw a plausibility fault but probably would not keep it from starting. The MAF will keep it from starting but I cannot tell from the information at hand.
Friday, August 22nd, 2008 AT 9:08 PM
